TR224 112lsa cam
Old Dec 1, 2005 | 03:00 PM
jakebdb56's Avatar
Talking TR224 112lsa cam
Just shopping around for a good cam right now and saw the TR224 from thunder racing. Wondering if this cam would be a good choice for a daily driven ECSB 2006 5.3L. mods are going to be pacesetter lt's, qtec dual 3" cutouts, modified intake manifold, custom tune from gforce, and maybe a TB stall if I have the money later on. possibly a TNT 100-150 shot. didn't know if anyone on this board had a similar combo or not. if so post up your combo and the results you got. dyno graph's would be rather juicy
Old Dec 1, 2005 | 04:06 PM
black4x4's Avatar
if you want to run it your gona need a bigger stall then a tb one. and i hope you dont mind lope cause that thing will lope bad
Old Dec 1, 2005 | 04:31 PM
TXsilverado's Avatar
thats pretty borderline on daily drivability. no real experience, only from what ive read in the forums. i was really considering this cam at one point. youll need atleast a 3000 stall and alot of people think its not good for a heavy extended cab. all of this is considering you have the 5.3. if you have a 6.0 rock on
after watching l33z71's big ol' crewcab 5.3 runnin DEEP into the 14's im considering the cam he used to get my fat truck rollin. 216/220 @ 114. it should give a noticeable lope, great drivability and work with a TB stall. once again no experience here, just ALOT of reading. im sure someone will correct me if im wrong anywhere.
Old Dec 1, 2005 | 05:05 PM
white1's Avatar
The grind on my cam is close. I have a bit more lift. In a rcsb 4wd, I love it. But I do have a 6.0. I ran a 218/224 before with my 5.3 and liked it too. I think you will need at LEAST a 2800 stall, but you'd be happier with a 3000 IMO. I ran the 5.3 with the 218/224 and no stall, it was ok, but I lost a lot of low end.
Right now, I have a Cam Motion custom ground cam that was ground for a 3000 stall. When my last tranny ate the dust, I went back with a Tb stall till I can save up some cash for another 3000. With the 32's I wasnt happy with it, but with some smaller tires I like it a lot. Can anyone say stalker? I pulled the Z-71 stickers, lowered it, and put some 285/60's on it Its real fun now. It ran a 13.7 before, Im ready to see what it'll do now when I get it tuned right and another 3000 stall.
Anyway. I think you would like teh TR224 but get a 3000 stal. Or get a TR220 it would work with a smaller stall.
Keep in mind, I drive mine everyday, and USE the crap out of the 4wd, and Im happy
Old Dec 1, 2005 | 05:15 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
TR220 would work better but you are going to NEED a stall to get the most out of the cam. Pretty much any cam you will lose bottom end so you need the stall to make up for it. I would still go with a 3K stall with the tr220 but it will haul *** for sure. I had a 222/224 112lsa cam in my old 5.3 and it had no nutts down low with a stall that only stalled to 2500. It needed a 3200 stall bad. You are a bit lighter and have less driveline loss since Im 4wd so IMO a 220 would be perfect and ALOT of guys are having great sucess with it.
Old Dec 1, 2005 | 05:39 PM
bluecajun5.3's Avatar
11 Second Truck Club
the comp 216/220 like tex said would be a good combo with a tb stall.
i think the 224 will be a lil too much for what you are looking for it being a daily driver.
the biggest i'd go is the 220, but be prepared to drop in a 3k stall in that ext cab.
Old Dec 1, 2005 | 05:59 PM
RandomHero's Avatar
I want to end up doing the tr220 cam with a 3000k stall, I have a feeling my tranny is about 20k from blowing So I might end up doing a 6.0 4l80e swap in stead. I think it would only be about $1000-1500 more expensive for the 6.0/tranny swap
Old Dec 1, 2005 | 06:29 PM
jerome's Avatar
i think 6.0/tranny swap is much much more than a cam swap
Old Dec 1, 2005 | 06:36 PM
1slow01Z71's Avatar
You can pick up a nice 6L with 80e for 2K add a cam and springs while your in there and a shift kit to the 80e so ur up to 2800 give or take not bad for the performance and strength you gain.
Old Dec 1, 2005 | 06:40 PM
ap2002's Avatar
I wish they made a 216/220 with a high lift.... I am so tempted to do a TR220 with the TB stall but dont know??? do yall think I can get away with this combo??? I really want to stay with the TB stall.......
