torque and degrees
Old May 8, 2011 | 10:23 AM
CodyBoy's Avatar
Default torque and degrees
Never heard of or dealt with this before this rebuild of my 5.3
How critical is the degree rotation? If it calls for 15 lb ft then 80 degree rotation.
I made my own degree wheel with a piece of cardboard from a Papa Johns pizza box and a protractor.
So if it calls for 80 and you only get +- 3 or 4 is that OK?
Thanks.
Old May 9, 2011 | 01:20 PM
CodyBoy's Avatar
So no one has the answer?
Old May 9, 2011 | 01:31 PM
Gadgetized's Avatar
If you take your time, and make a good pattern it should be very accurate. Don't just stop somewhere between the pepperoni and mushroom, take it exactly to the degree and it will be correct. The degree method is actually more accurate than torque. You are actually after proper stretch of the fastener. The degree stretches it the proper length, other than different lubricants causing an inaccurate torque reading.
Old May 9, 2011 | 06:08 PM
budhayes3's Avatar
PT's Slowest Truck
+1, and you in turn end up with even compression of the gasket. You can mark the heads of the bolts that you're toruqing at 12 o'clock, then make sure that they end up at the degree interval necessary.
Old May 9, 2011 | 07:30 PM
brent5631's Avatar
Dont fret too much though. Get it as close as possible but a little off wont hurt much.
madmann26
Apr 29, 2020 09:17 AM
Wolftrk99
Oct 2, 2015 08:17 AM
Lthompson
Sep 30, 2015 06:48 PM
Cammed4ever
Sep 30, 2015 03:38 PM
chopperloco
Sep 28, 2015 08:40 AM
