telling a lq4 from a 1q9
Old Feb 3, 2009 | 11:52 AM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Originally Posted by ap2002
only way to tell is to look at the pistons
LQ9 = flat top piston
LQ4 = dished piston
thats what i figured
Old Feb 3, 2009 | 11:53 AM
Originally Posted by twolow02fransen
all the 03 ups had the dbw 99 to 02 had cable
Damn, thought I was onto something. The only other 6.0 I've looked at is a buddie's SSS in hawaii and it was dbw so I figured that was the difference.
Old Feb 3, 2009 | 07:10 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The spacer was only on the 6.0 with the iron heads on it(99-early 00), once they got aluminum heads, they went with the shorter crank.. Pull a plug out and check the pistons, theres not a truly easy way to tell, unless you seen what it actually came out of..
You got that back wards 99-00 had a longer tail crank... in 01 they went to the shorter tail crank and used a spacer to compensate for use with the 4L80E Transmission
Old Feb 3, 2009 | 07:15 PM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
which one is better just out of curiosity
clemsondave's Avatar
I'm kinda curious. Would numbers from a compression test be higher on an LQ9 than an LQ4. I understand that is not the purpose, but wouldn't the avg number be higher given the CR was higher?
Old Feb 3, 2009 | 07:23 PM
Mangled03gmc's Avatar
Baltimore Whore
LOL yah I did, I knew what I was thinking, just rushed, typed it out wrong hey it was 6 in the morning LOL...
Old Feb 3, 2009 | 07:25 PM
nonnieselman's Avatar
same as tryin to tell the difference of a 4.8/5.3...
Old Feb 3, 2009 | 08:03 PM
1989k1500's Avatar
The lq9s have better rods until 05 then the lq4 has the good ones too. The lq9 is higher compression, that could be good or bad depending on what your doing with it.
Old Feb 3, 2009 | 09:02 PM
PappyDan's Avatar
Tribe Shaman
if the motor is still with the body the only way is by the vin number.
if it is sitting out just a motor only, you have to rip in to it.
Old Feb 3, 2009 | 10:27 PM
dlt76028's Avatar
screwdriver in the spark plug hole... not a big deal
