take a guess, please
Old Oct 3, 2006 | 09:08 PM
reveille5's Avatar
Default take a guess, please
Anyone want to know what happens when you hook up the pcv hose to where the breather is supposed to be attached on the throttle body and take the breather hose and hook it up to where the pcv hose is supposed to be attached on the intake?
I'll give you a hint....... 1 quart of oil per 100 miles consumption. (at 70 mph).
Old Oct 4, 2006 | 07:22 AM
Gran Patron's Avatar
Did you accidentally mix'em up or something? But damn sure did burn some oil.
Old Oct 4, 2006 | 08:00 PM
reveille5's Avatar
Someone else did.
Old Oct 4, 2006 | 08:50 PM
budhayes3's Avatar
PT's Slowest Truck
...direct suction of oil into the intake...I'd do a top end cleaning, you're induction system is probably full of nasty gunk and goo. A can of Seafoam should help, just follow the instructions on the can. It will clean your intake, valves and combustion chambers.
Old Oct 4, 2006 | 10:37 PM
reveille5's Avatar
A direct suction of alot of oil into the intake.
Thanks for the recommendation.
Old Oct 5, 2006 | 09:54 AM
FarmerBeau's Avatar
Sexy Party Mod
That guy that installed your cam is a phucking idiot.
Old Oct 5, 2006 | 10:16 AM
LesPaul's Avatar
how do you **** that up
Old Oct 5, 2006 | 11:46 AM
white1's Avatar
Yep, guess he is. Damn Jim, glad you got it fixed, how did that get mixed up? Sorry bout that.
Old Oct 5, 2006 | 12:00 PM
Nick™'s Avatar
it got mixed up when the valve covers were swapped around to their correct position, remember that they were swapped for a Whipple install that never happened, the hoses were all rerouted and the proper hose wasn't present at the time
Old Oct 5, 2006 | 10:53 PM
reveille5's Avatar
Yep, Nick, you are correct. The ******** at Doer's Automotive did that. The moron did not install my valve covers to the correct position which created a confusing issue. The dick heads at Doer's had aftermarket hoses so it was confusing.
I am just glad I finally found the oil consumption problem.
I am sure gas prices will finally fall some as demand for oil will be reduced.
