supercharged L33 silverado build
Old Apr 22, 2013 | 11:22 PM
05silverado4x4's Avatar
Default supercharged L33 silverado build
hey everyone, I have decided I want to supercharge my 05 Silverado 1500 4x4 with the l33 engine. I know there is a lot more that is needed to be done than just slapping a supercharger on there and calling it good. so I will need your guys help. I am an ASE certified tech, went to school and everything so I do know my way around a car and have or have access to just about any tool. but I am actualy going back to school for a few more classes and getting into some diesel classes, so I am on a budget. being on a budget I think it would be best to do this build in stages. so I have some time in between stages where I can save up but still drive my truck as it is my daily driver. so I need your guys help on the perfect setup for me, and how I should build it in stages.
current truck setup: 2005 Silverado 1500 4x4 5.3 vin b., 3.42 gearing, stock 4l60e with corvette servo. nelson performance tuned pcm.
so for the stages, I thinking maybe in this order.
stage 1- tune (already have), headers, cai, shift kit, gauge pod w/ gauges.
stage 2- cam, diff gearing, retune
stage 3- built 4l60e or 4l80e swap, stall converter, retune
stage 4- supercharger (magnuson, vortec or whipple) retune.
stage 5- small lift, probably 2-4 inches and 33'' tires
so what do you guys think? do those stages sound like they would be good to go by? or is there more I need to add? keep in mind don't have the cash to buy all the parts at once. also as for all the parts, I would love recommendations on brands and setups, like what brand supercharger to go with? gear ratios? cam? intake? ect.. also is a built 4l60e more budget friendly than a 4l80e swap. like i said this truck is my daily driver so i need it to be the most reliable and drivable setup i can get. i don't race my truck but i don't drive it like a grandpa either, i do like to have fun with it. i also do tow some small trailers and snowmobiles, nothing huge tho. I have done tons of research on setups like this, but now that I want to slowly build up my truck, I want as much help and knowledge as I can get!
thank you all in advance for any and all help! let me know if you need any more info! this will be a long term build but I think it will pay off in the end.
Old Apr 23, 2013 | 12:27 AM
darnie's Avatar
id get some ebay headers, and wait to find a good deal on the intake, and prob cam. deff get a 4l80e. im in mine so far $1600 with a $1100 TQ converter. thats ntb... your on the right track step wise for the most part. also id de a tru-trac with your gears. you'll what a tranny cooler as well. if you want check out my build thread im pretty much running what your doing except im gunna go turbo soon...
Old Apr 23, 2013 | 12:39 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
My recipe for mid 11's with a blown L33.
2001 ECSB 4x4 Z71, L33 5.3, Radix, 2.8 pulley, 92mm FAST throttle body, 4" intake, VHP Trucker cam, 216/224 .551/.551 115 lsa, 1.8 Crane Gold roller rockers, 4l65E, SC3000, ARH 1 7/8 into a 4" AFE Duramax system, HPTuners 2-bar OLSD, 4.10/Tru-trac, Cal-Tracs, 3-5 drop, 11.62 at 113.31 mph.
Things I'd do differently: 4L80E.
Things I'd recommend for you, since you want a small lift and 33's: 4.56 gears.
Options: I think any of the popular PD blowers will get you there.
Old Apr 23, 2013 | 11:25 PM
just installed my nelson tuned pcm tonight! came in the mail while I was at work. wow wat a difference! truck drives so much better and you can tell there is a little more power! A+ to Nelson Performance!
I plan on pacetter ceramic coated longtubes, off road y pipe and 3'' back exhaust as my next investment. should I get the transgo hd2 shift kit for my 4l60e till I do a 4l80e? or should the trans hold up to the tune headers and intake just fine?
also as for the 4l80e swap. how much am I looking at spending on the whole swap and parts needed? what other parts will I need? and is there any specific year 4l80e I should keep an eye out for? will I still need to put upgraded internal in it? or will it handle the power of the supercharger? I want to get the whole truck built nice and stout before I do the supercharger so I know it will handle the power when I do get a charger.
also will the 4l80e have really tall gearing compared to my 4l60e? will I need to put different gears in the 4l80e to get it to a better ratio? or is it fine as is?
thanks again!
nick
Old Apr 27, 2013 | 07:40 PM
anyone? also I am looking to beef up my 4l60e till I can to the 80e swap, which will be a while down the road. what do you recommend doing/ replacing in the trans to beef it up? I will definatly be doing the trans go hd2 shift kit, 40k cooler, torlon check *****, new gm separator plate, 1-2 and 3-4 pinless accumulators, servo release kit, deeper trans pan. anything else I should do? should I do the trail blazer torque converter swap? or go with a higher stall? want this trans to hold up to as much power as possible without having to put in beefier internals. atleast for now
nick
Vash3233
Sep 22, 2019 01:18 PM
USMCvet0311
Aug 14, 2015 10:28 PM
jaypowe11520
Jul 29, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
Deceptarado
Jul 8, 2015 05:24 PM
