Should a lifter do this?
Old Jan 15, 2007 | 07:35 PM
Blow03SS's Avatar
Default Should a lifter do this?
I have had a very bad valve train noise at start up and then it goes away after 3-5 seconds, but even then I get some pretty heavy valve train noise. I took the heads off and one of the lifters did not comeout with the tray, as I went to take it out it was stuck in the lifter bore, I had to use pliers to pull it out. Could that thing have been stuck in there and only when it finally pumps up it will move? What do you guys think?
Old Jan 15, 2007 | 07:38 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
It should NOT be that hard to take out. You should be able to pull them out with a pen magnet if anymore force is required then something is up.
Old Jan 15, 2007 | 07:58 PM
Blow03SS's Avatar
Ok then I was kinda thinking that, Trying to think as to what would cause that thing to get stuck like that? I wonder if I should clean up the bore put in some new stock lifters and call it good. I really don't want to take the oil pan down to check that damn o-ring?
Old Jan 15, 2007 | 08:15 PM
1slow01Z71's Avatar
If I was that far into it I would check the o-ring.
Old Jan 15, 2007 | 08:55 PM
Blow03SS's Avatar
guess so , any ideas on where I can get some lifters cheap, I was running stock LS lifters in the 408 I think they are fine.
Old Jan 15, 2007 | 09:14 PM
onebadrubi's Avatar
ls7 lifters are 99$.
Old Jan 16, 2007 | 05:07 AM
Blow03SS's Avatar
Thanks, who should I buy them from for that price? Will they reguire longer push rods?
Old Jan 16, 2007 | 09:30 AM
thunder550's Avatar
High on diesel fumes
Scoggin Dickey has them www.sdpc2000.com
You should be fine with the same pushrods. The stock LS7 lifters require the same preload as the LS1 lifters.
Old Jan 17, 2007 | 05:01 AM
Blow03SS's Avatar
well I should have a new lifter kit waiting for me at the dealer today, not bad $105. All the ls lifters have been superceeded by the ls7 style lifter..or thats what I was told be SCD. I will replace that oring tonight, Im running out of things to replace.
JordanH
Nov 6, 2015 07:42 PM
gmcyukon
Oct 5, 2015 06:20 AM
zblee
Sep 19, 2015 06:33 PM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
