Should I hone/bore?
Old Jun 26, 2012 | 01:01 AM
Hivelocit's Avatar
Default Should I hone/bore?
Took the 6.0 down to a short block everything looks great but cylinder 4 has a light brownish discoloration circling the top about a 1/3 of the way around. Should I be concerned with this? Was kinda hoping to keep it stock, it's not deep just slightly ruff. Doesn't look like a crack, or from a head gasket leak, maybe it sat in the junkyard too long. Any suggestions in the meantime?
Old Jun 26, 2012 | 01:52 PM
slow67's Avatar
Gingervitis Addict
See if you can get it off with a scotchbrite pad and some oil.
Old Jun 26, 2012 | 03:32 PM
1FastBrick's Avatar
Custm2500's Rude Friend
It will come off with oil and a scotch brite bad.
A ball Hone wouldn't be a bad Idea either...
Old Jun 26, 2012 | 04:28 PM
Hivelocit's Avatar
Thanks guys! Funny I went shopping this morning and grabbed some scotch brites.. Will give it a try!
Old Jun 26, 2012 | 07:37 PM
06murder's Avatar
U could th cross hatching thing n pb blaster make it faster
kelleyperformance
Nov 10, 2012 02:33 PM
