Safe RPM before float
Old May 18, 2009 | 09:41 PM
BigCountryx's Avatar
Default Safe RPM before float
On a stock motor, particularly an LQ9. Stock cam, stock spring etc. Now I understand that shift points are determined by where the power falls off, but that's not the question. Just wondering what RPM the stock valvetrain get pushed past the limit. Does FI effect this any?
Old May 18, 2009 | 09:44 PM
Mangled03gmc's Avatar
Baltimore Whore
6k should be fine on stock springs...
Old May 18, 2009 | 11:21 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, but that's about as high as I would go on the stock equipment...
Old May 19, 2009 | 07:03 PM
Truckshop's Avatar
put a good set of springs on it and the valvetrain will pull higher than the truck intake will go.
Old May 19, 2009 | 07:36 PM
JoeGibbSilverado's Avatar
my tow haul settings are at 6500, u guys are scaring me, lol
Old May 19, 2009 | 10:13 PM
PathfinderJr's Avatar
yeah, I was kinda wondering about springs too with the little 4.8. Since it likes to rev out more, I didn't know if better springs and pushrods (weren't LS1 guys having bent pushrod issues at 5k+ rpm?) would be just good insurance.
Old May 20, 2009 | 12:55 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Boost will make valve float more likely. You should be running out of cam at around 5800 rpm anyways, with your stock cam. Pick out a nice cam & spring kit and put it in. It really wakes things up. Don't forget hardened pushrods.
Old May 20, 2009 | 12:58 AM
viciousknid's Avatar
Where's the Beef?
Yup. Peak HP on the 6.0 is like 5600-5800 tops. So shifting at 6500 with stock cam/springs is definitely a waste and only a matter of time before you drop a valve. They've gotta be floating at those RPM's considering they aren't made for it.
When my 5.3 was stock I had the shift points at 6k. no reason to go over without a cam and springs. IMO
Old May 20, 2009 | 10:00 AM
Think the 5800 rpm statement still holds true with a TVS 1900 added to the mix?
Old May 20, 2009 | 11:19 AM
Spoolin's Avatar
GFYS and STFU
On turbo's the bigger concern is exhaust valve float rather than the intake valves. Better springs are important on a supercharger but you should be fine unless you pully down quite a bit.
