Roller arm ratio? With the cam I'm runnng
Old Oct 24, 2014 | 07:23 PM
zaathur151's Avatar
Default Roller arm ratio? With the cam I'm runnng
I have a Comp xr275hr cam 54-426-11 - XFI? RPM High Lift
Its in a Lq9 with stock heads (317) running PAC single beehive springs needing help determine what is the best roller rocker 1.7 or 1.8 ratio for my setup?
Old Oct 25, 2014 | 12:19 PM
turboal1's Avatar
Default rockers
witch Pac springs ? you have to watch for coil bind you will be very close to .600 lift
and alinement over the valve tip. also valve cover clearance.
the only one's i found to fit the best were Summits own brand
if you want 1.8 roller's. they are really well made with big trunnions.
Old Oct 25, 2014 | 12:30 PM
Vortec350ss's Avatar
I would run the stock rockers...
Old Oct 26, 2014 | 09:57 AM
zero2sixT's Avatar
Depends on the ramp rate of the cam. 1.8s don't like a high ramp rate.
I run yella terra non adj. 1.7s. They are working out real well for me.
Only rockers I know of that need valve cover spacers are Harland sharps.
Old Oct 26, 2014 | 05:53 PM
zaathur151's Avatar
Why I'm wanting to buy roller rockers is I have no factory rockers and OEM rockers with trunnions would cost the same amount
Old Oct 26, 2014 | 06:04 PM
zaathur151's Avatar
PAC 1218s
Old Oct 26, 2014 | 06:31 PM
69Camaro427's Avatar
I wouldn't run the 1.8s unless you're upgrade the springs.
0.566/1.7 = 0.333
0.333x1.8 = 0.599
0.568/1.7 = 0.334
0.334x1.8 = 0.601
Old Oct 26, 2014 | 07:33 PM
zaathur151's Avatar
Looks like im going to try summit racing 1.7 rockers not seeing near the bad reviews vs. Other brands and there priced good.
Old Oct 27, 2014 | 08:06 AM
I'm really curious why you wouldn't run the stock rockers?
Old Oct 27, 2014 | 08:50 AM
I'm running yealla terra 1.8 and have had no issues in 30K + however I got mine slightly used for $150. I think $400 was the cheapest I could find them new.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
superchomper2003
Aug 26, 2015 09:39 AM
BigEd_72455
Aug 8, 2015 07:37 PM
Kaldar
Jul 27, 2015 06:42 PM
4B11T
Jul 13, 2015 03:48 PM
