reduce cam lope?
Old Apr 15, 2006 | 08:18 PM
reveille5's Avatar
Default reduce cam lope?
Is it possible to reduce the lope of a cam at idle?
Did a cam swap on Friday. Has, what I call, a noticable lope. So much so, it shakes the vehicle side to side. I have a 5.3 ext cab. 04'. Had a Nelson tune installed just after. Even after the tune, having trouble keeping the truck running at idle. Will a another re-tune fix the idle problem and "too much" lope.
Here are the specs of the cam.
Duration at .050"
219/222
Intake lift 564
Exhaust lift 551
Lobe separation 112
Centerline 108 degrees
advance the cam 4 degrees.
By the way, White1 and a couple of his buds did the swap and did a great job. Truck runs great after idle and a very noticable power gain.
Thanks.
Old Apr 15, 2006 | 08:30 PM
NoChrome's Avatar
Prolly the only way is to make it idle higher.
Old Apr 15, 2006 | 08:53 PM
white1's Avatar
Thats the only way I know of to reduce lope. I bumped my idle up and it cut down on the shaking a good bit.
Nick™'s Avatar
we can make a few scans for you next time you are in the area, just let us know and you can email that to Nelson to help him see what's happening
Old Apr 15, 2006 | 08:55 PM
goshawk23's Avatar
Truck addict
with my truck idling at 1000 with the 224/224 it don't lope as much. lower than that it lopes hard. i like it like that though
Old Apr 15, 2006 | 08:59 PM
reveille5's Avatar
Truck lopes pretty hard but the idle is at 500 (or a hair bit higher). I think if it were to idle at 700-750 should be ok.
Old Apr 15, 2006 | 09:02 PM
Kano's Avatar
raise your timing
Old Apr 15, 2006 | 09:04 PM
reveille5's Avatar
Default raise your timing
Originally Posted by Kano
raise your timing
How? With a tune?
Old Apr 15, 2006 | 09:37 PM
goshawk23's Avatar
Truck addict
yes, with a tune.
Old Apr 15, 2006 | 10:42 PM
budhayes3's Avatar
PT's Slowest Truck
Raise the idle...easiest way.
