Raising compression, Changing Lifters & Cam
#21
11 Second Truck Club
there's a guy on here "V8" . . . he ran nice times with modded heads and a 5.3
https://www.performancetrucks.net/fo...1&pp=25&page=2
#22
formerly ByuTrukFreak
So far here's what I want to do, Shave heads to get to 11:1 Comp. ratio, new head gaskets not thinner than.04, Cam 232/234 .595/.598 112LSA, LS7 Lifters & trays, new pushrods measured to fit. FAST LSXrt intake manifold,102mm t-body, 100mm Lingenfelter MAF, Larger intake tube, Line lock
Will call COMP & see if I might have PTV clearance issues. Might see if I can get that cam with a 113 or 114LSA to broaden Power Band.
Still not sure of Valve springs any others I could do research on that y'all know of. I'd be interested in looking up open and closed pressures.
Install, repaired transmission & converter, new radiator & E-fans, transmission temp guage.
any thing I'm missing, besides a few marbles?
Oh yeah some better drag tires, need to put all that power to the pavement.
Thanks guys, criticism, knowledge, opinions, all accepted.
#23
Does anybody know a good Machine shop Around New Orleans or Baton Rouge I can bring my heads to? I'm in Golden Meadow anybody nearer?
#24
Heads are going to Womack Head & Block in Denham Springs 2 moro.
Will I need to use new head bolts? I have ARP bolts now.
If I change Cam do I need a new bolt for crank snout?
Does anyone have the two piece timing cover? Any troubles with it?
#25
Can someone answer this?
#28
Just letting y'all know what's going on, I got the engine out the truck, had the heads shaved .050, I got a cam spec from Patrick G, It's getting made by EPS, it's 226/230 .598/.600 113+2 LSA. I'm putting the FAST LSXrt manifold & 102mm tb, LS7 lifters. I'm gonna try to put some pics up but not sure how to resize them or lower the amount of bytes. Is there a way to set the camera so the pics are not too many bytes? Maybe if I lower the picture quality or change the pixel settings?
#30
