Question for heads, my set up
Old Jan 29, 2008 | 05:08 PM
Mangled03gmc's Avatar
Baltimore Whore
Default Question for heads, my set up
Would I benefit from running these heads http://www.texas-speed.com/shop/item...d=649&catid=40 on my current set up, vs my mildly ported, milled 317's, using stock gaskets. For anybody that has time where would that put my comp ratio at using them heads. I don't know the full deal on the head game yet but am trying to learn... Thanks anybody who throws a helping thought in. I am aware that more money is better for alot of mods, but ???
lq4 stock
stock intake for now, hope to switch to ls6 or fast.
224 581 on a 112.
bolt ons.
Thanks alot all
John
Old Jan 29, 2008 | 05:33 PM
Truckshop's Avatar
how much are the 317's milled. being that they are cnc'd i am sure they will flow better the comp jump will determine how much?
Old Jan 29, 2008 | 05:45 PM
Baltimore Whore
.020k, with a good valve job..
John
Old Jan 29, 2008 | 07:00 PM
Baltimore Whore
T t t
John
Old Jan 30, 2008 | 02:14 AM
PappyDan's Avatar
Tribe Shaman
man i pinch pennys, i can not afford 1000.00 a head.
your 317 heads has a 71 cc chamber.
now the LS6 head has the same size valves, the same size ports,
but it comes with a 64 cc chamber.
now for just 1000.00 i can get a good used set of 243's off of ebay.
break out my dremil and put a good polish on the ports,
and have the machine shop rebuild them, and come out with a couple 100
in my pocket.
Old Jan 30, 2008 | 05:55 AM
iamkeniff's Avatar
I'm with you man...that's COSTLY...
on a stock LQ4 243s milled .025 with stock head gaskets will give you a 10:5 compression.
If you were to swap to Flat Tops and leave them Unmilled, and run stock gaskets, you'd have an 11:1x compression.
That's what Richard told me at WCCH, I've got them emails, and the Pms if you'd like to see those instead. Richard is the ****, just PM him with your thoughts and he'll try his best to work up the best combo for you.
Good Luck
Old Jan 30, 2008 | 02:17 PM
Cuerva's Avatar
11 Second Truck Club
My 317's massaged/milled .030" stock valves/stock gaskets have worked great for me.
Old Jan 31, 2008 | 12:35 PM
rgvsierra's Avatar
i have a friend that bought those heads and is gonna use them on a setup like yours, but with a 228 cam. i'll let you know how much he gained track wise.
Old Jan 31, 2008 | 12:47 PM
IMD's Avatar
IMD
Banned
also. with your set up, even if you went to the PRC heads, dont wast money on a fast intake, unless you are really going for all out numbers. the truck intake sticks with the ls6 intake on flow all the way up to 5500 RPM, and makes better real world low end numbers. if i were you, id either go for the PRC heads, or mill your 317's a little more to get some compression back up, and do converter (if you havent already) and some rear end gears.
Old Jan 31, 2008 | 01:03 PM
Baltimore Whore
yah I am not sure on how much more I can go on my heads, I think I rembered hearing .030-035k off, but if I do that can I still run my 7.4 rods? I am leaning more towards the ls6 intake vs the fast, once my trany gets here, I wanna run a tt3000 or about that, I have 4.10's in the garage. So i would def pic up hp running them prc heads?? over mine at this point. I would like to have a mid- low 12 truck off the bottle
rgvsierra i have a friend that bought those heads and is gonna use them on a setup like yours, but with a 228 cam. i'll let you know how much he gained track wise.
def let me know. Thanks alot guys
John
