pushrod length
Old Feb 2, 2012 | 09:48 PM
stangstomper68's Avatar
Default pushrod length
Ive got a 5.3 build Im basically done with. Last thing on the list is what size pushrod to use. Setup I have is a fresh 5.3 with 862's that have been cut .020. Lift on the cam is 605 and 610. Anyone know what size I should use?
Old Feb 3, 2012 | 02:17 AM
midevil1's Avatar
Guessing I would tell you to order 7.375's but I would measure to be exact.
Old Feb 3, 2012 | 03:21 AM
TimDave217's Avatar
i know comp cams makes a tool to check the exact length you need basically looks like a pushrod and just put it in and adjust to where it need to be and that will tell you what size you need. theres other ways to find out but im not sure what they consist of.
Old Feb 3, 2012 | 11:13 PM
midevil1's Avatar
I use the Comp Tool, but there are others out there that are cheaper. You really need to measure and remember that you will need between .050 and .080 of preload on the lifters..
Old Feb 5, 2012 | 05:23 PM
thanks guys i appreciate that. It looks like it will be 7.375
JordanH
Nov 6, 2015 07:42 PM
jtphelps289
Sep 29, 2015 12:00 PM
97_ek
Sep 23, 2015 09:16 PM
bisqikss
Sep 8, 2015 03:35 AM
