pushrod length
Old Mar 10, 2011 | 05:32 PM
CouJoe56's Avatar
Default pushrod length
so i have a 5.3, patriot performance cam,GEN 3, stock heads, LS7 lifters.
what would be a good length for my pushrods? someone told me stock and i dont trust myself with the length checker
Old Mar 10, 2011 | 06:42 PM
skeet's Avatar
stock length should be fine
Old Mar 19, 2011 | 11:14 AM
guero68's Avatar
throw in some 7.4 and go...i have the same set up you..i am running a comp cam
Old Mar 19, 2011 | 11:26 AM
AndysC3's Avatar
Dont the LS7 lifters have a higher cup than the stock ones? Might want to measure the preload just to be on the safe side.
Old Mar 19, 2011 | 11:45 AM
RibeiroBJJ's Avatar
Praise The Lowered
I thought the same thing but GM now lists them as a stock replacement for all Gen 3 motors as far as I could find.....
Old Mar 19, 2011 | 02:02 PM
Gadgetized's Avatar
You should ALWAYS measure the length. The easiest way to do this is to turn the bolt down on the rocker until there is zero lash (rocker tip is just touching the valve tip). Count the turns until you have reached your 22 FT LBS of torque. Most people shoot for about 1 1/2 turns. You don't need a pushrod length checker, but they are a nice tool to have. This method is for non adjustable rockers.
Old Mar 25, 2011 | 11:06 AM
SVC707's Avatar
*sorry to hijack, but didnt want to start a thread on the same topic*
stock lq4 long block but going to swap in an LS6 cam, ive read ill need new pushrods too
7.4?
JordanH
Nov 6, 2015 07:42 PM
jtphelps289
Sep 29, 2015 12:00 PM
97_ek
Sep 23, 2015 09:16 PM
bisqikss
Sep 8, 2015 03:35 AM
