Push rod length confusion
Old Jan 11, 2013 | 09:43 AM
Sales2@Texas-speed's Avatar
Former Vendor
Thanks guys for clearing that up. I've never heard that before.
So if I measure comps 7.400" pushrods with calipers, it won't read 7.4?
No, they'd be about 7.417-7.420" or so.
Old Jan 11, 2013 | 12:45 PM
Ferocity02's Avatar
Correct, as Matt said, they will read a little longer. How much longer depends on the diameter of the pushrod, the diameter of the oil hole, how its chamfered, etc. This is why gauge length is used because it is more consistent.
An even more accurate way to measure preload is to use a dial indicator if you have one. Basically just put the needle on the rocker where the pushrod sits, make sure the needle is parallel to the pushrod, and tighten the rocker down. As the lifter collapses with preload you will be directly measuring it on the dial indicator. I did this once on all of the lifters when I was diagnosing a tapping sound.
cheyenne383
Nov 13, 2015 09:24 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
sTNT971
Sep 26, 2015 04:22 PM
