Originally Posted by vanillagorilla
(Post 4177045)
Anybody know the gph a high volume pump flows? I could figure out what will happen given the orifice size of the squirters.
It looks like Katech is adding the squirters only to LS7 engines. LS7s have a very healthy flowing pressure pump to start with (they also have a scavenge pump), the pressure pump will actually flow so much so they can fill an upper end with oil on a high G sweeper and cavitate the pump on an 8 quart system. In 08 or 09 the LS7s got the 8 quart oil tank increased to 11 quart. |
When my PCV system was messed up, I was oiling the tops of the pistons pretty good. With the results I was getting (detonation, fouled plugs), the bottom is probably a better idea.
:jest: |
| All times are GMT -5. The time now is 01:41 AM. |
