Piston Squirter....
Old Apr 9, 2009 | 10:59 PM
  #41
Just Enough's Avatar
Originally Posted by vanillagorilla
Anybody know the gph a high volume pump flows? I could figure out what will happen given the orifice size of the squirters.
I'm sure from your previous post you have the knowledge to run the calculations. The oil system losses (bearing clearance leakage) are a non-linear unknown variable that will turn your well intentioned calculation into a ball bark guess.
It looks like Katech is adding the squirters only to LS7 engines. LS7s have a very healthy flowing pressure pump to start with (they also have a scavenge pump), the pressure pump will actually flow so much so they can fill an upper end with oil on a high G sweeper and cavitate the pump on an 8 quart system. In 08 or 09 the LS7s got the 8 quart oil tank increased to 11 quart.
Old Apr 9, 2009 | 11:50 PM
  #42
MikeGyver's Avatar
When my PCV system was messed up, I was oiling the tops of the pistons pretty good. With the results I was getting (detonation, fouled plugs), the bottom is probably a better idea.
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
