-   INTERNAL ENGINE MODIFICATIONS (https://www.performancetrucks.net/forums/internal-engine-modifications-158/)
-   -   Piston Squirter.... (https://www.performancetrucks.net/forums/internal-engine-modifications-158/piston-squirter-438646/)
Wilde Racing Apr 7, 2009 08:32 AM
Piston Squirter....
Ever sence I head the new ZR1 vette had piston squirter, I've been searching for some pictures and wanting some for the older engines....
Then I found GM-high tech had a short add for Katech. Apparently they have started making piston squirters for the gen 4's...... hmmm.... Anyone with a big HP build got any plans on using them???? I'm going to look into the "slight machine work required" and give Brian nutter a call....
BlackGMC Apr 7, 2009 09:04 AM
errr, what do the "Piston Squirter" squirt? oil, gas, laffy taffy? Sorry i have never heard of them before.
Avalanche2002 Apr 7, 2009 09:08 AM
They squirt oil onto the underside of the piston to provide additional cooling for the pistons.
BlackGMC Apr 7, 2009 09:12 AM
interesting, thanks clearing that up. So that was a NO on the laffy taffy? j/k...
KySilverado Apr 7, 2009 09:37 AM
Yep saw those trick little pieces on the LS9. Thought it might not be a bad idea.
Wilde Racing Apr 7, 2009 09:52 AM
Yea, the squirter sprays engine oil on the bottom of the pistons to remove heat.
Pretty standard on turbo diesel engines.
philntx Apr 7, 2009 10:17 AM
http://i88.photobucket.com/albums/k1...orvette_zr.jpg
Integral piston squirters in the crankcase oil galleries were essential in making the LS9 live under prolonged high boost. "Our analytical tools told us early on we would be in big trouble without them," says Jim Cremonesi, DRE (design responsible engineer) for the LS9 cranktrain. "We see a significant drop in piston-dome and pin-boss temperatures. It's the best way we know to pull the heat out of the piston when making this much power."
Katech versions:
https://ls1tech.com/forums/generatio...squirters.html
Wilde Racing Apr 7, 2009 10:33 AM
Mmmmmmmm, prolonged high boost..............
thunder550 Apr 7, 2009 10:37 AM
Take your truck out to the salt flats. I wanna see a standing mile top speed of 170 or better.
Wilde Racing Apr 7, 2009 02:25 PM
Ummm 135 is fast enough...... Of course that was in town.. LOL
