Piston clearance
Old May 5, 2011 | 08:39 PM
CodyBoy's Avatar
Originally Posted by Matt@Texas-Speed
What piston is it, that definitely makes a difference in where you should set piston to wall clearance!
FYI: When you buy a piston that is labeled 4.030" bore, that will typically be right at the actually bore size of the hole, and the manufacturer will have built the clearance into the piston by making it 4.026" or so. Also, be sure you measure the piston 90º from the pin. Pistons are sort of egg-shaped, and measuring anywhere else is not right and will distort your readings.
I'm using the original stock pistons.
lukn4trbl355
Oct 21, 2015 11:19 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
turbo6c3
Oct 5, 2015 06:11 PM
sTNT971
Sep 26, 2015 04:22 PM
