patriot gold life
Old Jan 14, 2010 | 07:00 PM
southern_chevy's Avatar
Default patriot gold life
How many miles do you guys have on yours and what is about the max life to get out of them? Both cams have been under .560 lift so nothing that big but just looking into mileage to start getting them checked and to look into a new set.
Old Jan 16, 2010 | 07:41 AM
NoShow's Avatar
I'd probly have em checked if I had over 75-100k of normal street use. But I'm certainly not the authority on the subject. Most speed shops can check those, though
Old Jan 21, 2010 | 06:25 PM
come on somebody got to have some miles on some and some in site
Old Jan 23, 2010 | 08:21 AM
03 BLACKOUTSSS's Avatar
I only have about 7K on mine, so I bring nothing to the table. Check over on tech, they might already have a thread like that.
Old Jan 23, 2010 | 08:26 AM
https://ls1tech.com/forums/generatio...ring-life.html
Old Jan 23, 2010 | 09:29 AM
budhayes3's Avatar
PT's Slowest Truck
Valve spring life will be affected by how agressive the cam lobes are and how high you consistently spin the engine, obviously a more agressive cam that spins higher will have shorter valve spring life...
Old Jan 23, 2010 | 11:19 AM
nxredsled's Avatar
I have thirty thousand on mine and checked them about three thousand ago and still have no problems and my cam is 585 lift hope that helps
flatblack83
Jan 3, 2026 07:10 PM
SlvrSierra4.8
Oct 7, 2015 09:48 AM
SlvrSierra4.8
Oct 7, 2015 09:46 AM
slocaddy
Sep 25, 2015 12:42 PM
CashDudeHomie
Aug 3, 2015 10:58 AM
