P/R Sizing...?
Old Oct 18, 2012 | 11:53 PM
Hivelocit's Avatar
Default P/R Sizing...?
Hey guys measured my P/R length with Comp Cams 6.8 checker, and I'm coming up with 9.5 turns or .475 plusing that with 6.8 = 7.275 and adding .075 for LS7 lifters giving me 7.35 is this math correct?
Engine is a 2005 LQ4 with 317 heads milled .005, LS9 gaskets, isky tripple12 212/212 212 cam, and LS7 lifters.
Problem I'm having is I bought 7.4 pushrods already (did not account for the heads being milled for cleanup) should I return them for 7.35's? Is that .05 absolutely critical?
Old Oct 19, 2012 | 12:02 AM
Atomic's Avatar
I have a gauge for that
0.08 preload on ls7 lifters is fine
Old Oct 19, 2012 | 12:40 AM
Hivelocit's Avatar
.08 will net me 7.355, .045 shouldn't give me much trouble will it?
Old Oct 19, 2012 | 12:48 AM
Atomic's Avatar
My bad I added wrong. You have 7.4s and you measured you need 7.275. So right now you would have 0.125 preload which is too much. The most I have seen guys run is around 0.100. I would shoot for 0.08 preload so around 7.35 or 7.355 is what you want.
Old Oct 19, 2012 | 01:48 AM
Hivelocit's Avatar
Dang that's what I figured, when I tried torquing the rocker with the checker at 7.4 I noticed there was too much tension. Hopefully I can still trade them for the right set!
Old Oct 19, 2012 | 02:35 AM
smokeshow's Avatar
Mod with training wheels
And you were giving your cad students ****!
Old Oct 19, 2012 | 09:23 AM
Sales2@Texas-speed's Avatar
Former Vendor
With those measurements I'd recommend a 7.350" gauge length. That's about .075" of preload, which will be great for the LS7 lifters. We shoot for between .050"-.090" on them.
Old Oct 19, 2012 | 12:25 PM
Ferocity02's Avatar
I've run 0.075 preload on my LS7's for years, appears to be working! I needed 7.350" pushrods with the stock heads and gaskets, and then 7.325" pushrods when the heads were milled 0.022" with LS9 head gaskets.
Old Oct 20, 2012 | 08:53 AM
Hivelocit's Avatar
Perfect! Thanks guys went ahead and exchanged out the 7.4's for the 7.35's providing I did it right I should be well within spec! What PR sets are most running with FI? I went with the Comp Magnums, might should have done the High Techs, but figured I should be fine?
Old Oct 21, 2012 | 02:43 PM
Ferocity02's Avatar
Any aftermarket pushrods will be fine with FI. I could be wrong, but I don't think adding FI puts much more strain on the pushrods.
