One over sized piston???
Old Aug 2, 2010 | 03:47 PM
Phantom's Avatar
11 Second Club
Default One over sized piston???
So this guy has his truck tore apart. Doesn't have a lot of help or money. He takes his motor to a "well known" engine builder. One cylinder is completely screwed because of another "new and improved" comp918 failure. This well-known engine builder doesn't want to sleeve the block, just wants to put one .020 oversized piston in that one hole and leave the others stock...
Now, I'm no engine expert, barely a novice...but that doesn't sound like a recipe for success to me...thoughts???
Old Aug 2, 2010 | 03:49 PM
dirt track racer 81's Avatar
Same situation here lol https://www.performancetrucks.net/fo...d.php?t=466743
Old Aug 2, 2010 | 04:10 PM
built408's Avatar
Wouldn't it just be cheaper to buy another 6.0 or even a 5.3 if he is on a budget? The machine work would probably cost almost as much as a complete motor. Just a thought.
Old Aug 2, 2010 | 04:13 PM
He has a SSS with an lq9...their charging him $2700.. USA Racing Engines in the Houston area.. I have $1800 in my forged 370 short block.
Old Aug 2, 2010 | 04:32 PM
LS1FREEK's Avatar
13 Second Truck Club
I wouldn't do it... Even if he gets it balanced, having one larger piston just doesn't seen like a good idea to me...
Old Aug 2, 2010 | 04:34 PM
LS1FREEK's Avatar
Wouldn't he need to run bigger bore head gaskets? And wouldn't that one piston then also have slightly more compression?
Old Aug 2, 2010 | 04:36 PM
yea at higher rpm one hole is going to have more compression , more power, and be leaner than the rest and hes spraying a 150 shot to it.
Old Aug 2, 2010 | 04:40 PM
LS1FREEK's Avatar
Yep, I agree with you completely!
Old Aug 2, 2010 | 06:33 PM
silver-mod-o's Avatar
Hunt&Fisherator
See my post in your thread Tyler
- now there's also my motor for sale for 1800 too. Complete longblock
Old Aug 2, 2010 | 06:42 PM
how much you want for it
