is it ok 2.................
Old 01-09-2008, 01:40 PM
lethalyoyo's Avatar
Default is it ok 2.................
I am going to install some 42# injectors for the cam i put in will i need a tune right away or is it ok to drive around for a bit????????
Old 01-09-2008, 01:43 PM
truckmann's Avatar
You will need a tune right away. You will run way way rich if you don't get tuned for them when they are installed.
lethalyoyo's Avatar
thanks bro that all i need to know, so should i have him ruff tune it before i install
Old 01-09-2008, 01:55 PM
truckmann's Avatar
Your tuner should just need to make some adjustments to the injector settings to get you going.
Old 01-09-2008, 03:23 PM
joshua022's Avatar
Yeah, you definetly need a tune you could wash the cylinders and lose your compression if the new injectors run at hte same duty cycle as the small ones..
Old 01-09-2008, 03:53 PM
brobradh77's Avatar
def, new tune for bigger injectors
Old 01-10-2008, 10:59 AM
OnyxSilveradoSS's Avatar
will bigger injectors add any perf gains?? or just get the duty cycle down??
Old 01-10-2008, 11:15 AM
adam1803's Avatar
Well if you were going lean with smaller injectors they would add performance, but mostly its just to provide fuel to support mods.
Old 01-10-2008, 11:17 AM
adam1803's Avatar
Do you have future plans that will need the injectors? If not, i am fairly sure that your stock injectors will support that cam no problem
