oil pump or spun bearing??
Old Oct 17, 2011 | 07:20 PM
joeyc125's Avatar
11 Second Truck Club
Originally Posted by thunder550
Did you figure out what the actual cause was? I'd hate to see you put it back together and tear up a new cam and set of lifters. I'd be curious to see if the lifter actually went bad or if it was just a casualty of being run with no oil pressure.
I agree with looking into this, running the engine with no oil pressure does basically the same thing as floating the valves, the lifters aren't pumped causing them to bounce off the cam instead of follow its profile, obviously not under as severe load as high rpm valve float, but not good either way. Just make sure you look into it, it would be a bummer to put it back together and have the same issue. Also, those cam choices are vastly different, lol. What are you looking for out of your setup? What stall converter? gears? turbo? etc.. I am a fan of the smallish cams such as what I'm running (218/218-112, .57X lift), makes for a fun and responsive street combo.
Also, this is just my opinion, but I am very picky about cleanliness when I tear apart an engine, I would do your very best to get as much of that metallic sludge out of everything as possible. I wish you could prime the oil pumps on these engines like you could with the distributor drive on sb/bb chevy's to flush it out.
Old Oct 17, 2011 | 07:29 PM
chevyboy.520's Avatar
what can i look for, as far as low oil pressure problem? i know the lifter being how it was, was causing the low oil pressure after it went out. but what would cause low oil pressure before the lifter was smahed?
as far as cleaning everything up, ill be spending several hours and alot of parts cleaner get everything clean. it has been bothering me that the oil came out the way it did, cuz that means everything has **** in or on it.
Old Oct 17, 2011 | 07:37 PM
the truck isnt my dd anymore. i love choppy idles, and the way Slowlsx's truck sounds nasty as hell, and ifmine sounded like that it would be sick. But id like to really just get the best power and performance from it. i have 4.10's and a 3400 stall. with my 218/224 .600/.605 111lsa cam it woud spool fast, and pull hard. my trucks sweet spot was from a 50 roll, anything under it would spin.
so i want to get the best performaning cam period.
Old Oct 17, 2011 | 07:45 PM
joeyc125's Avatar
In that case, you could go a little bigger with it. I would do the Isky 218 218 112 over the triple 12, or bigger if your turbo will support the rpm without choking. Just remember, with turbo's, just because the cam can make N/A power to 7k doesn't mean it won't fall off hard well before that with a smallish turbo. Ex. my 365 falls off hard about 5600 due to my small tc76 turbine side, while Spoolin is running a slightly smaller cam (isky 215-114 vs my isky 218-112) and makes power well over 6300 I think, but he has a better flowing turbine side on his gt42.
Old Oct 17, 2011 | 07:52 PM
thanks for the info. Jake (smokeshow) has been explaining turbos and cam working together. i know im limited to what the s465 will put out. but eventually ill have to get a s475 haha.
jake always make fun of me cuz i want my truck to lope like crazy weither it helps or not haha. so id like to get a bigger cam.
im leaning toward the 228/222 115+2 cuz i might get it cheaper then $400
Old Oct 17, 2011 | 08:03 PM
joeyc125's Avatar
Pm stock48, he usually has a couple good turbo cams laying around. Usually a good price on them too!
Old Oct 17, 2011 | 08:28 PM
i sent him a pm asking about the triple 12. ill send him another one asking about other cams aswell. thanks for all the help
Old Oct 18, 2011 | 10:32 AM
thunder550's Avatar
High on diesel fumes
If it was me I'd replace the oil pump. They aren't too expensive. I had two oil pumps fail within about 6 months of each other on my old 408 setup, I think the bypass valve stuck open on them. Better to replace now than to have to tear everything down again IMO. Also, if you're ever in a situation where you start your truck and have no oil pressure, get a tow home....it will be cheaper than replacing torn up engine parts.
Old Oct 23, 2011 | 03:10 PM
So I picked up some parts plus some are on order.
Stuff I have
1. Ls7 lifter
2. Ls2 lifter trays
3. Arp cam bolts
4. TSP ported ls6 oil pump
5. Front cover gasket
6. Water pump gaskets
Stuff I'm waiting on
1. Isky "Triple 12" cam
2. Ls9 head gaskets
3. Cam retaining plate w/bolts
4. Oil pick tube O ring
5. Gm header studs
Everything but the cam should be here tomorrow. So I can star putting stuff together and finish cleaning it all.
Going a few weekends with out the truck sucks. Glad I have a DD to rock out in
Old Oct 23, 2011 | 04:52 PM
joeyc125's Avatar
Looks like a pretty good combo of parts you have there, very similar to what I'm using except I am using a 218/218/112. That triple 12 seems to be working very well for someone else on here, don't remember his name..
