Which oil pump to get? Listed 4 choices
For my cam swap getting the final parts bought! for s 2001 5.3L
Stock LS6 oil pump $106 /no o ring
Ls series Melling oil pump $106 /with new o ring
SLP Heavy duty oil pump $162 /with new o ring
LS Series Melling Oil Pump (High Volume) $140
The cam is a 210/218 on 116Lsa with 1.8 rockers gives .584/.584 lift
My stock oil pump idles with around 40psi pressure dont really want 30psi or greater than 50psi at idle with the new pump
the stock pump will do just fine the high volume ones are only good if you plan on running more oil like 8 quarts with only 6 quarts ive seen the pan get sucked dry at high rpms with a high volume in these style motors
Yea I was leaning towards the stock LS6 pump seeing as mine has 150,000+ miles and works perfectly. I just hate to have it off during the cam swap and not put a new one on, then 20,000 miles down the road it goes out. My dad has a 96 silverado stock with 330,000+ miles no oil pump issues. The old man refuses to get rid of that truck I guess he's to attached.
So is 4.8L 5.3L 6.0L truck/suv Ls2 Ls6 oil pumps all the same? I thought the Ls6 oil pumps had a lil bit more flow than the truck oil pumps.
