oil found in the intake manifold
Old Sep 12, 2010 | 12:27 PM
terravast4's Avatar
I have seen some people use a little filter instead of venting the passenger side to the intake tube. Is this ok?
Old Sep 12, 2010 | 01:48 PM
supercharged680's Avatar
Originally Posted by iamkeniff
what rpm do you spin your motor to? ive yet to find a lot of oil in mine. i run to 6800rpm an it pulls its *** off for being 5800lbs. im adding a catch can soon though just to be safe.
6500.. im thinking of adding a breather.. the catch can will solve it but not completely.. the breather will help imo.. where could i find out i went to a local speed shops he had 2 from k&n neither of them fit..
Old Sep 12, 2010 | 02:39 PM
terravast4's Avatar
I bought my breather from metco....screws in the place of the oil fill cap
Old Sep 12, 2010 | 03:32 PM
does it leak.. i read on ls1tech that it does..
where could i find one? part # would be helpfull as well.. my 1st choice would be a breather if it didnt help ill add a catch can..
Old Sep 12, 2010 | 06:10 PM
terravast4's Avatar
I would add acatch can first. I just added the breather to get more air in there. My breather has not leaked at all. has a rubber o-ring for a great seal. metcomotorsports.com and the part # is mbr0003 $46.99
Old Sep 12, 2010 | 09:12 PM
budhayes3's Avatar
PT's Slowest Truck
It won't really make a difference as the passenger side is actually the fresh air return to the crankcase, not suction to the intake
Old Sep 12, 2010 | 10:13 PM
terravast4's Avatar
So the line from the intake tube to the passenger head is pulling air in ? if I have a breather on the passenger side can I cap this off?
Old Sep 12, 2010 | 10:33 PM
budhayes3's Avatar
PT's Slowest Truck
I'd leave the breather on there or you may get excess vacuum from the PCV side
Old Sep 13, 2010 | 12:21 AM
terravast4's Avatar
No. leave the breather on the oil fill and cap off the barb on the passenger side.
Old Sep 13, 2010 | 04:48 PM
budhayes3's Avatar
PT's Slowest Truck
You can do that if you'd like to, just keep an eye on the breather, I've known those things to get a little messy in the past...
