Oil catch can
Old Nov 7, 2013 | 05:58 AM
xdmikey's Avatar
Default Oil catch can
Big waste of $$ or decent move for longer engine life?
I had threads replaced due to bad seals and in order the speed the process/get me back on the road quicker I opted to have the shop install take off heads/valves, new seals instead of machining my own heads.
I'm almost to 100 miles where I need to check the amount of oil in he can.
Do you think this will use more fuel since it's not reburning the old oil?
Mods: relocate the thread if needed.
Old Nov 7, 2013 | 06:10 PM
black00chev's Avatar
Slowest turbo build ever!
I have one and its great. Keeps a ton of oil/water mist from getting back into the intake and heads.
Old Nov 7, 2013 | 07:51 PM
xdmikey's Avatar
How often do you need to empty yours? After 120 miles there's barely anything in the bottom.
Old Nov 7, 2013 | 09:48 PM
brandon6.0's Avatar
I have had one for years. I can go around a year or longer without draining mine. It works great and keeps those new heads and intake looking great on the inside.
I rather have clean air than oily dirty air!
Old Nov 7, 2013 | 11:28 PM
I empty mine every time I change my oil.
Old Nov 10, 2013 | 08:11 PM
xdmikey's Avatar
Thanks guys
Old Nov 20, 2013 | 01:39 PM
RangerDan's Avatar
Has anyone run these in a cold/cooler climate? (where you might experience below freezing temperatures for weeks at a time)? Any issues with the cans at that point? I've been toying with the catch can idea since I tore my motor down and got a look at the amount of oil residue in places I wouldn't normally expect it (at least, not for the mileage I had at the time.) Anyway, sorry to hijack, hope its all good!
Dan
Old Nov 20, 2013 | 05:23 PM
I don't exactly have the weather you guys do, but I have had zero problems over the last 3-4 years I've had mine on. And that has included some pretty cold weather for here in VA.
Old Nov 20, 2013 | 05:31 PM
snakeatinZ's Avatar
Him downstairs
Bingo! They are mighty effective as I had one on my 04 gto. It takes about 3 minuets to empty so do it every oil change.
Old Nov 20, 2013 | 07:31 PM
darnie's Avatar
what catch can you all running?
