Noise after cam swap??? Please help
Old Oct 30, 2024 | 02:01 PM
Jamesstevens66's Avatar
Registered User
Stock lifters the cam I have is made to work with stock lifters
Old Oct 30, 2024 | 02:59 PM
strutaeng's Avatar
5 Year Member
I understand that, but I still think you need to double check.
Stuff gets machined wrong, parts gets put in wrong boxes, etc. Making a wrong assumption is sometimes a bad decision when it comes to these types of things, because in your mind, you've ruled out XYZ, but the issue lies there.
Remove the valve cover and see if there's a pushrod that has a lot of slack, which would indicate a lifter issue. And I'm not sure why some of them aren't getting lubrication, but that's a problem. See if there's a relationship between the loose rockers (if you have that) and pushrods w/o lubrication.
Old Oct 30, 2024 | 03:45 PM
DateNight's Avatar
And no to answer your question I did not replace the cam retainer plate
I wouldn’t be surprised that this is the problem.
Old Nov 1, 2024 | 01:02 AM
Registered User
well found out the cam shaft is chewed up put a camera there and it’s like if I was to grab a knife and scrap the sides of the lobs on the cam
my question is why did this happen
what causes the lifters to do this
cam defect? Off timing ?
truck had total 2-3 minutes of idle time
im guessing the chattering noise is the valves if its off timing
Old Nov 1, 2024 | 01:06 AM
Registered User
Originally Posted by Bach03SS
More than likely a lifter. Either collapsed or spun in the lifter tray. I would not run that anymore without more diagnosis. Could be getting metal all throughout the motor.
Was this bought direct through texas speed? China knock off TSP and BTR camshafts have started appearing on eBay and amazon. Those china cams have horrible hardening and heat treat problems. I hope that is not your case
the lifters that is on the chewed up lob is sitting in the correct position from what I could tell
Old Nov 1, 2024 | 05:31 AM
DateNight's Avatar
There is an oiling issue. Even if the cam was a tooth off it wouldn’t have caused this.
back to the cam retainer plate. That seal controls the oil to the lifters and needs the pressure to push oil through the pushrods. With no or low oil it will chew up lifters and a can quick.
Old Nov 1, 2024 | 06:01 PM
FFDP's Avatar
Off chance that the camshaft was a bad unit out of the box with poor metal quality.
But usually it's a oiling problem or the lifter failures and wipes the cam lobe.
Old Nov 7, 2024 | 07:59 PM
DateNight's Avatar
Did you find the issue yet?
Old Nov 8, 2024 | 09:28 PM
Registered User
yes timing was off badly when i reinstalled it
now im having a issue with push rod the exhaust side push rod is sticking out pass the heads not sure if this is normal or not all the others are same height
mike058
Dec 14, 2022 02:02 PM
joshua022
Jan 26, 2014 05:40 PM
reveille5
Aug 20, 2006 01:38 PM
02Reaper
Jan 21, 2005 11:25 PM
