no oil to rocker arms
Old Jun 19, 2013 | 02:48 PM
bad cutt's Avatar
Default no oil to rocker arms
I just got my motor back together last week, I had a bent rod, I replaced 1 rod and 1 piston as well as all the rod and main bearings, after it ran for a couple minutes I noticed a noise, I shut it off and there is no oil getting to the rocker arms, I have roughly 45 psi of oil pressure at idle. any ideas?
Old Jun 19, 2013 | 03:05 PM
Ferocity02's Avatar
Describe the noise that you heard.
How do you know no oil is getting to the rockers? Very little oil actually gets up to the rockers, especially at idle. I envisioned geysers of oil under the valve covers, but the oil actually just dribbles out. At higher RPM's oil will actually start to spay a little bit.
Here's a video I took of mine: 2012 11 13 18 05 12 411 - YouTube
Old Jun 19, 2013 | 04:16 PM
bad cutt's Avatar
a rattling from the top end removed the valve covers no signs of oil cranked the engine nothing at all came out of any of the rocker arms valve covers weren't wet and no oil on the head after the engine was running
Old Jun 20, 2013 | 08:25 AM
bad cutt's Avatar
last night I pulled the rear lower oil galley plug on the side of the block and I don't have oil coming out of it when cranking how is it possible for my gauge to work with no pressure to the rear oil galley?
Old Jun 20, 2013 | 08:40 AM
swift700's Avatar
Hmm, I wonder if you might have a problem with the dumbell behind the rear cover. Are you absolutely sure there is no oil at the top?
Old Jun 20, 2013 | 09:35 AM
swift700's Avatar
I'm not sure how you can have an oil pressure reading from the sending unit at the top but have no oil in the rear galley. I'd try a mechanical gauge in the sending unit hole.
Maybe your lifters aren't pumped up yet. If they're not pumped up then they wont send oil to the top. I'd dump oil on the rockers, run it and wait awhile.
Old Jun 20, 2013 | 01:27 PM
oakley6575's Avatar
Run a mechanical oil gauge for sure.
Old Jun 20, 2013 | 02:10 PM
Ferocity02's Avatar
The engine may not be spinning fast enough while cranking to move oil. Does the gauge show oil pressure while you're cranking? You could try cranking with the plugs out, that way it'll spin faster and have a better chance of making oil pressure. IIRC, with the plugs out mine would crank fast enough to create oil pressure.
Old Jun 20, 2013 | 02:26 PM
bad cutt's Avatar
dumbbell is in mechanical gauge is reading the same
Old Jun 20, 2013 | 03:03 PM
swift700's Avatar
Is there no oil coming up on both banks? Did you check both sides?
You'll need a fair bit of engine speed to notice the oiling.
