newbie-cam and spring ??
I have an 06 ECSB 4.8. I am going to buy the comp xr269hr cam(216/220 .525/.532). I want to know if the ls6 yellow springs will be good enough fo this cam. And should I buy new retainers also. Already have exhaust, cold air. Yes, I will be buying long tubes, and getting tuned!!!
The yellow springs will work nicely. No need to spend on retainers. Use the stock steel ones. I hope you're going to put some stall in the converter with that cam. Power under 2500 rpms will be soft.
Good luck,
Richard
Good luck,
Richard
gmcyukon
Oct 3, 2015 11:03 PM
