Need more elect power
Old Oct 7, 2008 | 09:12 AM
wot_denali's Avatar
Default Need more elect power
I need more elect power to my 02 4.8 supercharged sierra so what do you think i can put to add more elect power?
Old Oct 7, 2008 | 11:43 AM
marlboroman71818's Avatar
what?
Old Oct 7, 2008 | 12:34 PM
Zick's Avatar
Maybe he has an electric supercharger.
No but seriously, we have no idea what your asking.
Old Oct 7, 2008 | 12:42 PM
InchUp's Avatar
I too am lost, with not a f^$3ing clue why a supercharged truck would need more electrical capacity...but if you have an electric hair dryer in your intake tube then I can see why.
Regardless of why, the answer is simple. A high output alternator, a Red or Yellow Optima battery and thicker wire cable between the alt and battery. Start there.
Old Oct 7, 2008 | 12:57 PM
thunder550's Avatar
High on diesel fumes
GM makes a factory 145 amp alternator. That would be a good upgrade, unless you need even more than that.
Old Oct 7, 2008 | 01:05 PM
L7 Sierra's Avatar
There are factory options for a larger alternator, and theres a couple of aftermarket options for dual alternators or just one huge alternator.
Old Oct 7, 2008 | 02:02 PM
wot_denali's Avatar
I had changed the alternator to 145 amp but still the truck showing low elect power ,one of the guys adviced me to but msd but i dont know which one to chose.
Old Oct 7, 2008 | 02:04 PM
thunder550's Avatar
What does MSD have to do with alternator size? I think you need to be more specific about what's going on.
Old Oct 7, 2008 | 08:01 PM
viciousknid's Avatar
Where's the Beef?
Increase the size of wire going between the alternator and the battery.
And as thunder said. Tell us what's going on so we can better help you. A supercharger isn't going to be affecting your charge so you may have a short some where.
Old Oct 8, 2008 | 05:31 PM
you know every once in a while I get the "charging system voltage low" warning on the lcd display but when it does it is never lower than 13.7 volts. as long as your voltage doesnt stay below 13.2 you should be ok unless you have a short
andrewlong
Nov 9, 2016 09:38 AM
Superman09
Sep 25, 2015 05:55 AM
Brandonlflr12
Sep 9, 2015 03:54 PM
andrewlong
Sep 8, 2015 10:25 PM
