Need to know the difference between the 799 and the 243 heads!
Old Sep 25, 2009 | 12:53 PM
nonnieselman's Avatar
Originally Posted by m3srt
i belive i have a 799 on the drivers side and a 243 on the pasengers side
were you the one to post up about it awhile back when you first got your truck? your SN looks fimialar..
Old Sep 25, 2009 | 06:55 PM
joeyc125's Avatar
11 Second Truck Club
Only the ls6 243's have the sodium filled valves, the ones that came on the ls2 and 4.8/5.3 and the 799's do not have them. The ls6 ones also came with the yellow springs.
Old Sep 26, 2009 | 12:53 PM
LS1FREEK's Avatar
13 Second Truck Club
Hey thanks man... That helps alot i thought all 243's had sodium filled valves.
Old Sep 29, 2009 | 02:16 PM
JAX04's Avatar
is this true?
Old Sep 29, 2009 | 02:33 PM
TXsilverado's Avatar
not all 243 heads came with sodium valves...only the 243 castings used on LS6 engines came with sodium valves. all of the others use your standard valves.
Old Sep 29, 2009 | 08:12 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
If you take a look here you will find all the answers you need.
https://www.performancetrucks.net/fo...d.php?t=434396
Old Feb 25, 2015 | 08:18 AM
paul59's Avatar
Registered User
Default 2011
I have a 2011 Silverado I have the 243 heads and my uncle has a 2013 Silverado but he has the 799 heads (why and which one are better)
Old Feb 25, 2015 | 10:11 AM
I want to say that one was die cast and the other is sand cast. both the same design. I wouldn't say one is better than the other.
Old Feb 25, 2015 | 12:06 PM
RS/SS 4.8's Avatar
10 Second Truck Club
My 07+ 4.8 has 243 and my brothers 2010 5.3 has 799.
Old Feb 28, 2015 | 08:14 AM
92SS Wagon's Avatar
<TECH ONLY> GM Head Casting Info - PerformanceTrucks.net Forums
good info that's for posting that link
