need help on 408
Old Nov 7, 2011 | 01:59 PM
Prochrgd5.3's Avatar
Default need help on 408
i have a 408 with cnc ported 6.0L heads, vic jr. intake, 60lb injectors, 85mm tb, stock coils, and procharger with 12lbs of boost. my problem is the passenger side cylinders seem to be running fine but driver side is not. i pulled plugs on the drivers side and 2 cylinders look like new and 2 cylinders are black and the passenger side plugs look fine and are all the same color. ive checked all the wiring and have found nothing wrong from what i can tell
Old Nov 8, 2011 | 05:15 PM
charlie_riggs's Avatar
clean injectors
Old Nov 8, 2011 | 10:09 PM
TXsilverado's Avatar
check spark, fuel and compression.
Old Nov 21, 2011 | 02:30 PM
MPFD's Avatar
11 Second Truck Club
What are your plug gapped at? I have seen blower car's blow out the spark with aggressive pullies.
Old Nov 21, 2011 | 03:17 PM
caddy03pimpin's Avatar
Just a thought maybe o2sensor
sTNT971
Sep 26, 2015 04:22 PM
11MPG
Sep 10, 2015 08:34 PM
chevy6.0fan
Aug 20, 2015 07:10 PM
chevysten
Aug 13, 2015 07:36 PM
