need cam ID help..
Old Apr 3, 2008 | 08:10 PM
foxls1's Avatar
Default need cam ID help..
stock ls2 cam ..i have the PN but the cam i received is a single bolt type and i dont see the number. i was suppoed to be getting a stock ls2 cam witch i thought was 3 bolt. can i get some help here.
guess i need to know what numbers are on the stock 2008 4.8 cam AND the numbers that are on the ls2 cam.
Old Apr 4, 2008 | 04:51 AM
foxls1's Avatar
bump any ideas
Old Apr 4, 2008 | 11:25 AM
InchUp's Avatar
No ideas here on which part numbers but if it came down to keeping that camshaft, all you'd have to do is change the cam sprocket to the single hole. Hopefully somebody will chime in here with the numbers you need.
Old Apr 4, 2008 | 11:43 AM
Dark Halo's Avatar
to my understanding the ls2 cam is a single bolt style cam. Not sure about the part number
Old Apr 6, 2008 | 11:57 AM
foxls1's Avatar
K, my 08 is a single bolt. The ls2 cam i received is a single bolt. I thought the ls2 cams were 3 bolt but after calling around i think we think it came outta an 07 vette. not sure tho
Old Apr 6, 2008 | 07:41 PM
Truckshop's Avatar
early ls2 are 3 bolt cams. the 07 and later are single bolt.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
