Need Cam Help
Yet another cam thread... I have a '67 Bronco that I swapped in a '02 5.3L & mated it to a NV4500. I use the rig both as a pavement pounder & as a wheeler. I am running 37" tires but am well geared to handle them. Thanks to the tranny I cruise on the freeway around 2k. The rig has good power throughout the entire power band but I always want more. The motor is stock except for the typical intake, headers, exhaust, & tune. I was sold on the LS6 cam as it is cheap & makes good power up top & doesn't require a tune, but don't know if I would regret the upward shift of the power band. I want a cam that won't hurt my low end too much but will give more stab up top. I would love to have a hearty lope, but don't want to sacrifice low end to get it. I LOVE the idea of sticking in some yellow springs & a LS6 cam for cheap & calling it good because if I can get 25whp for $150 it sure beats 40whp for $1000 (tune, cam, springs, pushrods).
Also future plan is for a low boost quick spooling front mount turbo, but that is probably years away.
What would you guys recommend?
I just happen to have a COMP XR 265 that i am selling. Great low end, i used it in a 4x4 that towed. It is the low lift, 212/218 114lsa. Mild idle and no vacuum issues or engine lights. I just went bigger after only 2500 mi!! I am sure others will comment that this is great DD cam. Pm me if interested.
gb
gb
Sorry to drag this back up, been stupid busy the last few months. I am still looking for a good cam for my rig. It is a true dual purpose rig, it sees lots of highway & lots of trail. I wouldn't call it a dedicated mudder or crawler, more of a total trail rig. I am running an NV4500 behind my 5.3 so I don't need to worry about a stall. The rig weighs in at around 5,000 lbs & I have 4.10 gears. I should have gone 4.56, but I was only running 35"s when I set up the gearing.
I've been reading up on the old man cam, TR220, & the XR 265 all look like good options. I need torque, but love top end as well. Something that wouldn't require a tune would be a big plus. Opinions?
I would keep an eye out for a good USED 212/218 or some kind of vinci cam around the same specs or close to it.
Thanks for the input guys. I almost went the ZO6 cam route last year but decided against it due to the shift of the powerband to the right. Looks like time to wait for a good deal.
lawhitediamante
Aug 12, 2015 12:14 PM
