my turn for push rod questions
Old Sep 25, 2008 | 07:47 PM
TURBHOE's Avatar
Default my turn for push rod questions
ok, i need to valve springs. i'm running 10psi and around 4800 rpm my eng stops pulling. i've decide to go with patriot golds. so here is my question. can i run my stock push rods? i ask this because i want to change my cam but i don't have the money now. so i don't want to change push rods just to have to change them again in a couple months.
Old Sep 25, 2008 | 08:54 PM
budhayes3's Avatar
PT's Slowest Truck
I wouldn't run the stock pushrods, they're definitely a weak link IMO.
Old Sep 25, 2008 | 10:54 PM
TURBHOE's Avatar
so say i want a ls6 cam. can i use 7.4's for both stock and ls6 cam? if i can do that then i wouldn't mind getting them.
Old Sep 25, 2008 | 11:49 PM
7845's Avatar
Banned
you can run the stock pushrods for now. look at this way. instead of bending a valve youll bend a pushrod. they are cheap tho like 70 bucks or so
Old Sep 25, 2008 | 11:55 PM
charcold-bowtie's Avatar
ive been running the ls6 cam with the 7.4 hardened rods with no problems or added valvetrain noise. been around 6 months. From what ive collected in that argument, you just lose some preload on the lifter, no valve lift loss. 90 bux on ebay for the pushrods comp 7.4's
Old Sep 26, 2008 | 01:04 AM
TURBHOE's Avatar
what do they "recomend" for ls6 cam? and if its like 7.425 can you use those with stock cam? what would happen if you bent a rod? just a lose in power or a lose in a head/motor? never researched this part of the build i guess i should have.
Old Sep 26, 2008 | 08:57 AM
Wilde Racing's Avatar
How do I change this text
You will have a dead hole. Run the stock ones until you can buy the hardened versions, but measure them to see what size you actually need.
Old Sep 26, 2008 | 07:25 PM
TURBHOE's Avatar
so it won't destroy anything? are these things so weak that i have to worry?
Old Sep 26, 2008 | 08:25 PM
How high of rpm. I personally think you will be fine with that cam..
Old Sep 27, 2008 | 06:18 AM
TURBHOE's Avatar
well when its said and done i would like to spin to say 6000 maybe 6500 but no more than that. this is why i was looking at the 2002 ls6 cam. but until i get the cam i figure no more than 6000 rpm if it will even pull that high. right now i would be happy to spin to 5000rpm but it will bearly do 4500. i will post a pic of a log from the track.
