MLS Head Gasket wont work on 01' 5.3?
Old Jul 7, 2009 | 01:46 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by A Low Dime
Mine is 01' with 862's, which had MLS gaskets when I popped the heads the first time.
Like I said you're fine with MLS headgaskets, just make sure you clean the deck of the block really well and you are good to go.
Old Jul 7, 2009 | 09:08 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by terravast4
it is the 97-98 LS1 (853 casting) and 2001-2003 6.0 heads recess on cylinders #3 and 6
I'm building an 03 LQ9, but I have no idea what year the heads are? I should be OK to use the MLS's right? I mean, isn't that what they came with stock?
Old Jul 7, 2009 | 10:32 PM
terravast4's Avatar
if you check the head on the comustion chamber side there is a little recess like half a quarter at either the #3 or #6 cylinder, if you have these heads the MLS gasket will not work. GM made a steel shim design that has teflon sealing material at the surface that specifically seals around these recessed areas. Th MLS gaskets do not have a sealing surface at this spot and that is why they have a tendency to leak.
Old Aug 2, 2009 | 08:09 PM
1FastBrick's Avatar
Custm2500's Rude Friend
This is the only valid information in this post. Thank you!
FWIW The 99 and 2000 model year 5.3/4.8L have the graphite head gasket. In 2001 They started using MLS gaskets. I believe it was the early 1999-2000 862 heads that either had the recess or not depending on either when or were they were cast. I havent been able to get exact info on that.
As far as coolant leaks go, if you use the wrong gasket in the wrong application then yes you will end up with a leak. I am not 100% sure why but occasionally some of the newer MLS equipped blocks do leak between the head and block matting surface.
I personally did an 05 avalanche 5.3L with flex fuel option that was leaking between the head and block. It was repaired some were else and withen a week showed signs of leaking again. They heads were checked and reconditioned and the block showed no signs of warpage or other damage. When I reassembled it, I used a Glue between each layer of the MLS gasket and on the top and bottom of the gasket near the front of the block were it was leaking. The vehical has since been shipped to Dubai and has hasn't had a problem since.
Old Aug 2, 2009 | 08:34 PM
dlt76028's Avatar
did you get those heads done at that place i told you about?
Old Aug 3, 2009 | 01:10 AM
A Low Dime's Avatar
13 Second Truck Club
Sure did. They are doing Scott's heads are machining my block as we speak..
Old Aug 3, 2009 | 10:03 AM
dlt76028's Avatar
Sure did. They are doing Scott's heads are machining my **** as we speak..
WHAT???
Old Aug 3, 2009 | 11:11 AM
TVI's Avatar
TVI
Where are you all getting your machine work done?
Old Aug 3, 2009 | 12:18 PM
dlt76028's Avatar
Wes Automotive Machine Shop in Haltom City
Old Aug 3, 2009 | 08:51 PM
TVI's Avatar
TVI
Excellent, thanks. I actually live in Haltom City, too.
