MLS Head Gasket wont work on 01' 5.3?
if you check the head on the comustion chamber side there is a little recess like half a quarter at either the #3 or #6 cylinder, if you have these heads the MLS gasket will not work. GM made a steel shim design that has teflon sealing material at the surface that specifically seals around these recessed areas. Th MLS gaskets do not have a sealing surface at this spot and that is why they have a tendency to leak.
FWIW The 99 and 2000 model year 5.3/4.8L have the graphite head gasket. In 2001 They started using MLS gaskets. I believe it was the early 1999-2000 862 heads that either had the recess or not depending on either when or were they were cast. I havent been able to get exact info on that.
As far as coolant leaks go, if you use the wrong gasket in the wrong application then yes you will end up with a leak. I am not 100% sure why but occasionally some of the newer MLS equipped blocks do leak between the head and block matting surface.
I personally did an 05 avalanche 5.3L with flex fuel option that was leaking between the head and block. It was repaired some were else and withen a week showed signs of leaking again. They heads were checked and reconditioned and the block showed no signs of warpage or other damage. When I reassembled it, I used a Glue between each layer of the MLS gasket and on the top and bottom of the gasket near the front of the block were it was leaking. The vehical has since been shipped to Dubai and has hasn't had a problem since.
