Milling 862 heads on stock 5.3 engine for E85
I'm going to have my heads repaired:
- resurfaced
- valve job + new hardened exhaust valve seats
- spark plug thread repair
My engine is 100% stock but I'm running LPG (butane gas) which is quite popular here in Europe for cars with larger engines due to it's half-price when compared to gasoline. It is little bit similar to E85 when it comes to ideal compression ratio. But it can be aggressive to valve seats as it burns in higher temperatures, doesn't contain any aditives and is dry.
My question - if I have the heads milled to 0.02 inches, will I need to reprogram anything? Is this a safe number without needing other modification? I will use stock gasket size.
Thanks!
- resurfaced
Thanks!
Custm2500's Rude Friend
You will most likely need to change the valves out. GM did LPG conversions on the LQ4 engines under the RPO code KL6 The heads had different valve seat, as well as different Intake and Exhaust Valves for the LPG.
If you're not already on LPG you will probably need some type of Injector data for it to run properly.
I have not seen an LPG tune Vs. a standard gas tune so I couldn't say for sure.
imo .02" would need to be looked at for tuning as your bumping the compression from around a 9.5:1 to 9.9:1. it may run fine but i would still at least data log it.
GrooveCityZ71
08-31-2015 12:05 PM
