Making some changes
Old Nov 2, 2011 | 08:33 AM
  #31
SincalT/A's Avatar
I know some guys run 160-180 stats not sure how many.Aside from what everyone does the pros of lower coolant temps far out weigh the cons.I will say this...I gradually tried bringing coolant temps down to see where the sweet spot was in tuning and ended up disposing of my t-stats all together.Im not sayin thats what you should do but,I believe where your trucks runin is jus plain too hot ecspecially in Arizona.The rings only saving grace is the cylinder walls so with your coolant temp rise only being 3 degrees after wot.Tells me there is not much of a safety factor relieving them of undo stress.
Old Nov 2, 2011 | 08:34 AM
  #32
smokeshow's Avatar
Mod with training wheels
The head looked perfect. Small bit of burn where the plug protrudes from the head but no mechanical damage.
Old Nov 5, 2011 | 08:05 AM
  #33
smokeshow's Avatar
Old Nov 5, 2011 | 09:41 AM
  #34
Beatdown Z's Avatar
Laid Back
Ooooo, thats purdy!
Old Nov 5, 2011 | 10:21 AM
  #35
moregrip's Avatar
what a rush!
whats the measurement on that top ringland?
Old Nov 5, 2011 | 10:22 AM
  #36
Atomic's Avatar
I have a gauge for that
is that a gen4 valley cover?
Old Nov 5, 2011 | 01:05 PM
  #37
black00chev's Avatar
Slowest turbo build ever!
Were you able to keep the same bore size or was it honed out slightly? What all are you going to change after the engine rebuild?
Old Nov 5, 2011 | 06:24 PM
  #38
smokeshow's Avatar
Top ringland is 0.300". It is a Gen 4 valley cover. And I did hone it out quite a bit, so its a 365CI now.
Also changed a spring in the pump for converter holding pressure and had the converter stall brought down again. Making a bunch of aesthetic changes as well to clean it all up.
Possibly another mod coming in the near future
Old Nov 6, 2011 | 12:04 AM
  #39
smokeshow's Avatar
Old Nov 6, 2011 | 12:51 AM
  #40
Atomic's Avatar
How do you clear the crank pulley with the return right there? It looked too close when I was thinking about using that...
