Making some changes
Old Nov 2, 2011 | 01:28 AM
  #21
SincalT/A's Avatar
I mean why did the ring or rings get so hot they bound up against the ringland.
If you dont mind me askin where do the engine coolant temps run during and 30 secs after a full 1/4 pass?
Old Nov 2, 2011 | 01:33 AM
  #22
smokeshow's Avatar
Mod with training wheels
Factory ring gaps were too tight, I assume. Coolant temp at the beginning of the run was 198, end of the run was 198. Only logged for 13 seconds after the run but it rose to 201 in that 13 seconds.
Old Nov 2, 2011 | 02:06 AM
  #23
SincalT/A's Avatar
Thats too hot for a stock boosted engine.Im not sayin it was responsible for the rings because,im sure you could have adjusted the tune to accomedate the high coolants temps.Why so hot anyway?Dont tell me you like to have a hot heater.I know where you live.
Old Nov 2, 2011 | 02:09 AM
  #24
smokeshow's Avatar
It has the stock thermostat. Are a lot of the high HP guys swapping to colder thermostats?
Old Nov 2, 2011 | 02:40 AM
  #25
AKlowriderZ71's Avatar
11 Second Hall Moniter
Jake, was that the top ring, or the second ring? What did the other one look like?
Old Nov 2, 2011 | 02:48 AM
  #26
smokeshow's Avatar
Top ring. Other than some abrasion on the side, the second one looked fine.
Old Nov 2, 2011 | 07:10 AM
  #27
sureshot's Avatar
Just curious, what cylinder was this?
Old Nov 2, 2011 | 07:17 AM
  #28
smokeshow's Avatar
Number 3
Old Nov 2, 2011 | 08:27 AM
  #29
Atomic's Avatar
I have a gauge for that
im using a 160tstat
  #30
tiffo60's Avatar
what did the top of the piston and head look like in the same cylinder?
