LY6 question
Old Aug 2, 2015 | 09:12 PM
Jake75's Avatar
Default LY6 question
I purchased a LY6 short block that had a lifter seize up...no visible damage to the block or lifter bores. The outer cam bearing looks like it may have had a little piece of metal floating around it so i will be changing the cam bearings out. My question is if I'm going to take off the rod caps and the mains to check the bearings for damage would i be ok changing to arp hardware (main studs and rod bolts) with the std bearings? or will the bearings need to be re sized?
Thanks.
Old Aug 2, 2015 | 09:55 PM
Gadgetized's Avatar
I bought ARP rod bolts for my LY6. I plan on not resizing them, but I will be measuring them to be on the safe side.
Old Aug 2, 2015 | 09:58 PM
Jake75's Avatar
you got the part number for them?
Old Aug 3, 2015 | 08:36 AM
Gadgetized's Avatar
Old Aug 3, 2015 | 11:00 AM
George C....'s Avatar
Formerly ScreamingL
can not use ARP mains without machine work
Old Aug 3, 2015 | 01:07 PM
Jake75's Avatar
134-6006
Thanks
By machine work are you talking a line hone?
Old Aug 5, 2015 | 01:26 PM
TAPyvehc93's Avatar
Originally Posted by Jake75
Thanks
Install the ARP main studs and bolts and torque them to spec then take your measurements of the mains bores ID. The ARP studs will most likely change the ID of the main bores requiring it to be honed out.
Knightcrawler
Jul 18, 2016 08:30 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
chvy=power
Sep 8, 2015 11:06 AM
