LS7 lifters
Old Mar 11, 2010 | 02:17 AM
supercharged680's Avatar
Exclamation LS7 lifters
hey there guys im doing a vvt delete on my 09 denali.. H/C swap
crank sprocket
cam gear
timing chain
front cover
ill be shifting @ 6400.. i heard that the L92 lifters dont handle high rpm shifting.. so do u guys recommend changin the lifters to LS7.. < also do i need to change anything else when doing that
also.. my tuner today recomended that i install LS7 rocker amrs as well..
any suggestions i need replies its important cause im doing the swap in 2 weeks and i need everything to be ready because i have an appointment for the installation
Regards
Old Mar 11, 2010 | 03:13 AM
kwk174's Avatar
Well I got a set of Hi Lift Johnsons, and the comp cam replacement bearings for the stock rocker arms. And i am shifting at 6500.
Old Mar 11, 2010 | 02:51 PM
Ive heard alot of bad things about the ls7 lifters also, but maybe its just hear say.
I would think they would work well in a high rpm app. tho.
Old Mar 11, 2010 | 02:55 PM
f4tal's Avatar
the ls7 lifters are fine if you run the right pushrod length
Old Mar 11, 2010 | 09:43 PM
budhayes3's Avatar
PT's Slowest Truck
+1, that's what I'm going to be putting in my LQ9 I've actually heard that the expensive Comp R lifters (or whatever they're called) are junk. Just be sure to get your lifter pre-load spot on, as from what I've read, most of the LS7 lifter failures seem to be on engines where the installer didn't properly measure lifter preload, or just went by what they heard in a "what length pushrod" thread...
Old Mar 11, 2010 | 10:03 PM
Ferocity02's Avatar
What's the correct length? Most of the LS1/6 guys say 7.350. Most of the truck guys say stock 7.400 is fine...
Old Mar 11, 2010 | 10:05 PM
buy Morels
Old Mar 11, 2010 | 10:07 PM
f4tal's Avatar
You need a push rod checker to get the right length. they are like 20 bucks
There are too many variables to play it by ear... Do it right the first time so you don't have to do it again, just my $.02
Old Mar 11, 2010 | 10:16 PM
regcabls6's Avatar
I hope the ls7s are good. i had a set delivered today for my new engine build. I talked to alot of people before i bought them and everyone told me to go with the ls7 or the cts-v race lifters if your willing to spend the money on them. I hated my comps, click click click click all day long.
Old Mar 11, 2010 | 10:17 PM
Ferocity02's Avatar
Right, but checking the pushrod length and then ordering the right ones adds days/weeks onto the build, which isn't really an option when it's your only vehicle. I was hoping someone could throw in their two cents.
