LS6 cam installed today in 4.8 & electric fans
You'll be able to do better than that with the right tuning and driving habits. If you do a lot of highway driving, the converter will not be a real issue, as once the tcc is locked you have an "economical" 1:1 ratio.
No valve train or lifter noise at all sounds stock
I would run a 7.425 if i had stock heads
LS6 cam has a .025 smaller base circle
