Ls2 timing chain in 4.8?
I seen some people swap to a ls2 timing chain when doing a cam swap for added assurance cause it's heavy duty. I'm putting a cam in my 200 4.8. My question is do I need just the chain or the gear set to. Will just the chain fit my gears or are the adjustable like with a master link? Lastly does anyone have the part number I would need? Thanks guy.
I just changed the cam gear when I did mine. I didn't want to drop the oil pan or unbolt it enough to make it sag to where I could get to the crank gear or get the chain off, call me lazy. There wasn't too terribly much wear on it so I'm not sweating it.
I know in the streetbike/dirtbike world you dont mix a new chain with old sprockets or old sprockets with a new chain cause they develop wear charcteristics together.. i would imagine you could swap them seperately and be just fine, but then at the same time your chancing it if you cut a corner.. i personally would buy a complete ls2 timing set and swap the complete set.
Formerly 99-2door-08/30/2010
Just my $.02
Ok so the gears are the same as what's in my 4.8 stock. I just don't wann tear it apart and they are different. I'm deff wanting to do the chain and gears as long as thee like a direct replacement I might as well. Does this look like it will be what I need...
http://m.summitracing.com/parts/SLE-55003/Overview/
Thats an aftermarket double row.
The LS2 chain it self is GM part number 12586482
GM Factory Replacement Parts 12586482 - GM Performance Parts HD Timing Chain | SDParts - 1-800-456-0211
The IWIS Chain is Scoggin Dickey Part number SD3SR602
Scoggin Dickey Parts Center SD3SR602 - Timing Chain, Single Roller, Iwis | SDParts - 1-800-456-0211
Thank fast brick. For the extra few dollars, that Scoggin dickey looks like a no brainer. Do they have them with the gear set too? I see your name around here alot and really value your opinion and advice? Do you think I should change the gears also. My 4.8 has 86k and I'm going with a 212/218 .523/.529 114 lsa with ls6 springs and I'm undecided if I should keep stock 7.35 push rods or get comp 7.4's. Thanks. Sorry so many ?'s just trying to buy the right stuff.
