LS1 Piston Ring Gap
Old Sep 9, 2009 | 05:03 PM
00pewterz's Avatar
Default LS1 Piston Ring Gap
I have a stock bore ls1, just had the machine shop hone the cylinder walls true. I am going back together with it, and when fitting my rings I am getting .020-.021 on my top 2 rings. GM factory specs are top ring 0.009-0.017 and 2nd ring 0.017-0.027 . So the 2nd ring is within spec but the top ring is a little loose.
I guess what im trying to find out is, would that cause a problem? Should I get a set of oversized rings? The rings I have are Sealed Power P/N-E938K. Anyone have any suggestions?
Old Sep 9, 2009 | 05:27 PM
jetmann's Avatar
If you are using A stock piston and rod assembly, You should be Ok.
OHsixLS3
Nov 22, 2015 07:45 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
trxmxzx
Sep 29, 2015 07:42 AM
