ls hot cam
Old Dec 14, 2010 | 04:24 PM
z06 hellcat's Avatar
Default ls hot cam
anyone using a ls hot cam in a lq9 6.0, im using ls3 heads and intake off a 2010 camaro.
Old Dec 14, 2010 | 04:32 PM
00ChevyScott's Avatar
Wearin' da big hat
It's ****, don't use it
Old Dec 14, 2010 | 04:33 PM
KDavis04ss's Avatar
x2 Theres a lot better cams out there. With those heads you could use a lot more lift also.
Old Dec 14, 2010 | 05:16 PM
jrmchevyman's Avatar
X3 the ls1 hot cam is not a good choice imo especially for a daily driver, much better choices than it that can make more power. Search on here and you will see info all about this cam it runs rough even with a good tune and makes crappy power.
A Tr220 makes a lot more power than the ls1 hot cam and drives and idles great. You will want a decent tune of course though for any cam.
Depending on what upgraded converter you get and vehicle you have, you can put quite a bit larger cam in it if you wanted. Have you looked into a tsp224r?
Old Dec 14, 2010 | 06:16 PM
budhayes3's Avatar
PT's Slowest Truck
Old technology with lazy lobes that are hard to tune...pass
Old Dec 14, 2010 | 07:23 PM
1slowz71's Avatar
x5! theres way better cams out with way better performance
Silveradorst07
Dec 31, 2015 12:04 AM
superchomper2003
Aug 26, 2015 09:39 AM
fastjweb
Aug 15, 2015 10:47 AM
Jake99
Aug 8, 2015 07:56 AM
06 4.8
Jul 14, 2015 08:09 AM
