LQ9..what heads to use???
I purchased a used LQ9 engine. I figured since im in no rush to install it in my tahoe i should add a couple things here and there. Which cylinder heads out there fit this block and flow good numbers? I wanna use oem heads so aftermarkets are out the question. I'm planning on doing the 408 stroker kit. I saw some used Z06 heads on sale on craigslist for 500 complete with cam. Will this be suitable? Any input on this matter?
NA all the way....what i meant is stock oem castings. They will be sent out for porting. Aftermarkets heads are way too expensive and stock heads with good porting should be able to flow good numbers right?
