LQ9 + cam?
got an LQ9 and will have a 3000 stall, looking to buy a cam from a fellow member. wondering how compression and piston to valve clearance will be affected. also how it may perform NA as well as the occasional spray...
cam specs are; 223 225 564 571 114+3 |
i would say u should shave .5 off of your best 1/4 mile time. u should be in the 13's.
https://www.performancetrucks.net/fo...d.php?t=359725 This should answer your question.
jordan, who have you thought about to tune it. CAM?
I think that the LQ9 would respond well to that cam, go for it.
Anyone running a 224/228 580/581 on a LQ9. I will try to install it this weekend along with roller rockers, rods, springs and drop the tranny for a shift kit and 3000 stall.
that sounds like a real good set-up, let us know how it performs.... what lsa is that cam on ?? |
Thanks for the info guys! |
