lq4 rods valvetrain
Old Feb 12, 2010 | 02:01 PM
bluelq4's Avatar
Question lq4 rods valvetrain
Im building a twin turbo 6.0 sclb 2500 and i am wondering, does the ls1,6,2 have the same rod length and clearences as the lq4. i have searched for the specs to no avail. i am still wanting to keep the stock rod length if at all possible. also another question would be. what would be the recomended spring rate for the valve spring on 12 p.s.i of boost. also i have heard rumors about the rod bolts and wrist pins becoming weak when in turbo apps, which is normal in all motors. opinions and suggestions will be greatly appreciated.
Thanks-
Ben
Old Feb 12, 2010 | 02:09 PM
dirt track racer 81's Avatar
the rods should all have the same length. springs depends on the cam your going to run, if your going to run something similar to the ls6 cam you can run the ls6 springs. In all honesty for just 12 lbs of boost that can easily be done with a single turbo unless you want twins for the bling factor. you have to buy 2 of everything, it can cost alot unless you have the money to blow on it.
Old Feb 12, 2010 | 02:32 PM
bluelq4's Avatar
i have several turbos just laying around honestly. and tired of them taking up space so might as well put them to use. (i will be flipping the manifolds for the turbo app.) i was looking at several comp cams.
BTW comp has the Cam Quest 6 program free to download right now on their website!!!
part numbers/ grind...
54-414-11, XR296HR
54-416-11, XR273HR
54-426-11, XR275HR
for the first cam has
216.0 intake 220.0 exaust duration at .050-inch
.525 intake
.532 exaust
114 lobe centerline
112 intake centerline
and this brings me to my next question will this require fly cutting my pistons. still would like to keep a 9.5:1 comperssion ratio
Old Feb 12, 2010 | 02:47 PM
EVILGMC's Avatar
lets see some pictures/vids of your super stock tractor!
Old Feb 12, 2010 | 03:58 PM
bluelq4's Avatar
ill post up some vids and pics in (the truck stop) topic area under general dicussion for ya
Old Feb 12, 2010 | 06:05 PM
54-414-11, XR296HR
54-416-11, XR273HR
54-426-11, XR275HR
.525 intake
.532 exaust
114 lobe centerline
that cam wont need fly cutting. theres .600 plus cams with stock pistons and no flycutting
Old Feb 15, 2010 | 02:28 PM
bluelq4's Avatar
thanks for the info. goin to order 54-444-11 cam today .581/.588 114
lukn4trbl355
Oct 21, 2015 11:19 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Slammed silverado
Sep 28, 2015 06:14 PM
sTNT971
Sep 26, 2015 04:22 PM
